Turntable service centre in Chennai
hello,
this is Akhil i have recently found this philips turntable stereo system in the attic with the records too when i tried to connect it to the power supply i found out that the rpm is too slow for 33rpm position but the 45 and 78 rmp speeds are fine. i have greased all the parts and the motor spindle. i guess the idler wheel is slipping may be because the rubber has hardened. so could some one help me find out the make so that i can search for spare parts. even suggestions for a good service centre in Chennai would be really helpful. except for the make of the turntable i have no other specifications any specifications of this will be helpful.
with regards
Akhil
if the idler is gone, the speed will be wrong for all of the speeds
that looks like a philips hiq. I recall those were belt drive?
this seems like an issue with the speed setting mechanism (mechanical/electronic)
TEG : I've even ordered a new phono stage for the task, which will probably go on, just doing a couple of albums when I feel like it, for a long time. "
Why are you buying from the UK ?
Prices seem very high and which phono preamp are you buying ?
