TV and Stabilizer
pRosentR
Hyderabad
Do we need to have stabilizer in place for the latest generation of TVs from Sony, LG etc..? If so, could you please suggest a good stabilizer for a 65 inch TV.
I just got a APC UPS for the last TV i purchased. It has automatic voltage regulation that stabilizers provide but in addition it also has surge protection (that stabilizers generally don't provide) and if that wasn't enough it gives me about 15 mins of backup power. So if the power cuts out then your TVs sensitive electronics won't be effected.
I have only seen Sony advertise X-Protection as a separate feature to protect TV's. More experienced members might be able to help you better but this is just a noobs view.
I have always connected my expensive and sensitive electrical equipment like desktop, LED TV, OLED TV to good quality UPS not only for clean and stable power but also for a little bit of backup.
And for ACs I have always got custom-built heavy-duty stabilizers.
A couple of years ago on Diwali day there was a power surge in our area and everything on and connected to the inverter survived. Unfortunately though I lost quite a lot LED lights not connected to the inverter. BTW our inverter is always on UPS mode.
I think they do have voltage protection in higher end TV.
But why to risk?
I got V Guard Digi 200 in Amazon, it is 6 amp one. got around 3.5k
Ya 6 amp is a lot. it will more than enough for 65 Inch and all the stb, console, hometheatre.......
May I know the inverter model please?
Its better to have extra layer of protection as good UPS are not that costly.
You can go for APC Back-UPS BX600C cost 2.8k will provide better protection than stabilizer.
But calculate total watts before ordering.
I have had different inverter models over a period of time. Currently, I own Luminous and Exide and both have this mode.
If you are asking about this inverter vs UPS mode, there is a switch at the back side of inverters.
