Thad E Ginathom
No HT in the pc at all here, just looking for sound. And I won't even call it a media player setup, because the machine is in use as an everyday PC. I just want it to play music, etc, and to do so well, so Ubuntu has been my choice of what I want to sit in front of. I hope never to have to step back on the Windows road.
Yes it is: RTL8111D on a Gigabyte GA-890GPA-UD3H, rev.2.1, bios ff.
Seems to be a bit of a thing on this motherboard, according to my googling some time back. People reported replacement boards doing the same thing, so I decided to live with it. Sometimes the device will not come up. A reboot usually fixes it, and if it does not, then powering-off (hard, at the power supply, not soft with the button) always does. Sometimes, also, I'll see the router-port light flickering, in which case I know the net won't work, even though dmesg says the device is up.
There never seems to be anything more revealing in the system logs: just if the device is up or down. This can happen booting XP too; it is not a specifically Linux problem.
It is a pain, but even more of a pain to dissemble it and got through the returns hassle for an occasional fault.
			Sorry, but the logs, etc from that particular install are long-goneIt it some realtek chip, can you send me your dmesg/log in private.
Regards ...
  ) but that's fine. If the system is telling, hold on, processing something important at the moment, then that is exactly how it is supposed to be
 hyeah:
hyeah: :lol:
 :lol:
 :sad:
 :sad:
