Re: "UNDER-RESTORATION" vintage PHILIPS Radiogram with GARRARD RC-121 TT & BC6A VALVE
This is an early 60's model. Around that time Philips was suffering a midlife crisis and often came out with some odd ball designs. This radio is one of them.
1. Output Transformer less design. The speaker will have an impedance of 600 ohms.
2. It is a plano model. High and Low audio frequencies are produced by two separate amps using 2 x EL86 tubes. Kind of bi amplification
3. The IFT frequency is 452 Khz. In your pics the IFT looks suspect. I am sure it is damaged internally.
4. The copper coil you see has fallen lose from a ferrite rod. Its not ordinary rod. You can rotate the ferrite via a knob for best orientation and receiving of MW signal. Its called a Ferroceptor. In your radio this device is missing. Try to locate it.
As rightly pointed by Mr venky, it is not stereo despite the appearance. But the sound quality will be approaching hi fi standards thanks to the transformer-less output stage and the biampli design.
Can it be restored to its full glory? Certainly provided the IFT's, tuning condencer and coils are ok, and you are able to recover those magnificent 600ohm alnico speakers. Under normal circumstance these radios wont have a great collector value. However, considering it is/was a family treasure I think its worthwhile. It wont cost you a lot of money for sure. But start looking out for a donor set for parts to make the task easier.
As for the changer I wouldnt bother too much with it. Perhaps you can simply retrofit a better changer/TT.
Just a word of caution. These radios have High voltages running thro them. Dont just plug it into a wall socket. That PSU condenser is a bomb waiting to explode. Take an informed decision. In case of doubt walk away from it, preferable towards a technician who has worked on these radios. There are still plenty of them alive. He should also have a RF signal generator to align the radio. Prior to contacting a technician, you can do a thro cleaning.
1. Vacuum/Blow out the grime
2. Cleaning with a petrol using hard and soft brush. Let it air dry for a couple of day after that. I dunk the chassis in a couple of liter of petrol for cleaning
Even the dirtiest radio chassis can look nice after a clean. This is what I did to the last one that came my way.
On a tub for cleaning
Before
After
