Universal remote confusion
mk15
kota
Planning to buy a Logitech harmony urc.
Am confused between 525 (@2700 on eBay) and 650 (@3900 on eBay).
Please suggest what should I go for. Have heard that 525 is a battery guzzler but supports 10 devices vis-a-vis 650.
Which is a better buy. I am confused and as this would be my first urc purchase, I have no first hand experience on them.
Sent from my iPad using Tapatalk HD
I have previously used the 525 model. Yes it will drain batteries quickly. Four AAA batteries will last only less than a month even with moderate use. You can use rechargeable batteries though.
I use the 525 and use eneloop rechargeble batteries and they last me a little more than a month on heavy usage, no idea on the 650 though
I have bought the 525 model and initially it seems to be working fine but dont know whether it will continue working this way.
