That is huge stretch for me , btw what is the difference between b9 and c9
C9 is brighter and has a newer processor.
Panasonic 800DPlease specify the model so that I can check on shops
FX or GX. FX is 2018 n GX is 2019Panasonic 800D
The app store may be limited though. You may need to use an exrernal media box/stick.FX or GX. FX is 2018 n GX is 2019
I am not seeing gx options on onlineThe app store may be limited though. You may need to use an exrernal media box/stick.
@Marakk : how the sound quality of c9..? I am planning to check the retailer for the final price .
Or do you expect any pric drop if 2020 model arrived..?
I called couple of retailers and there not coming down below 1.4 for c9, may be I have to visit and bargain.During Diwali, you should be able to get BX for about 1 lac
Any idea about samsung q60 qled one..? Or anything from samsung.
Understood , but considering we are spending more time in home, i thought of using this time with better viewing experience.Q60 doesn't have FALD. Q70 does, but Sony X950G is better. Let's some blooming happen, but controls fluctuations and black details better. That's why I recommended that. Q80 will cost just as much as OLED, so no point.
Now is not a good time to be buying tbh. You'll have to wait for everything to open up a bit more and rhen bargain.
sorry to ask back to back doubts , what about oneplus qled..? i thought it is ahving decent reviews..? is that option is worth to consider..?
Ok to summarise , for upgrading my tv these are the options.Again, no FALD. For good HDR, which is a bigger upgrade in my view than 1080p to 4k, you need FALD and peak brightness of 600 nits at least. Most TVs in India don't meet that.
If you are with strict budget .. please go and check Panasonic GX800D . It is far superior in that budget compared to Sony,LG, Samsung.@Marakk
I have call d couple of retailers and all are trying to upsell B9 instead of c9 and suggesting there will be a good cash back offers for that. And they told they can't discuss the final price over the phone.
Suppose if the ptice for b9 and x950g is almost same which should ni go for..?
And I was reading through the forum and found the discussion about burn in issues of oled, in my usage of daily 4-5 hours subtitles will be there for all the shows or movies, will that be a risk for burn in..?
@Marakk
@Marakk : Any idea about todays launched TCL models..? anything worth to consider
