rahulsinghania
Hi ,
I am planning to set up a dedicated home theater room. The Room size is 220 sq ft (22 ft long and 10 ft wide ). I have decided on the amp. It will be Denon AVR x2000. But i am not being able to decide on the speakers .
1.I listened to Focal Sib & Cub 5.1 . It sounded good.
2.Then, i listened to Polk audio (Front : TSX 440 T , Sub : DSW Pro 660, Rear : TSX 110 B, Center : TSX 150 C). Polk sounded great. But it went slightly over budget. ( Budget was about 1L-1.2L including the amp).
I am confused whether for my room size Focal Sib & cub would suffice or should i go for Polk (by pushing my budget a lil higher) ?
