[Urgent] Please suggest external hard drive? [from US]
rohitmusic
Pune
Can someone please suggest good external hard drive?
Budget: $100+
Usage: Music + data backup
Minimum capacity: 1 TB
Thanks Koushik!
There seems couple models. Please see here.
This one looks good.
The one that is lower priced is USB 2.0 and other one is USB 3.0 which is higher priced. IMO, you MUST go for 3.0 as with 2TB it is obvious that you will transfer large chunk of data which is painfully slow using USB 2.0
Even if you don't have 3.0 compatible machine it is only matter of time that you will have one. 3.0 is the technology of the hour. Don't walk backward in technology for some 20-25 dollar.
Thanks Koushik, your are correct, 3.0 will have faster data transfer speeds. I will get the 3.0 version.
^^Yes and that's the reason I gave you the link :)
The ebay link that I gave is the one I bought few days ago.
Thanks Koushik, I think I can rest my case and get some other suff.. :P
(BTW the ebay link deal aint active anymore)
Cheers!
