USA made Harman AVR item to be used in India
kurups
bangalore
Hi All,
I have planned to buy the Harman Kardon AVR3650 Model from USA, but plan to use this in India.
The Voltage rating on this shows 120V/60Hz. In India the standard available voltage is 220V@50Hz. The Max Power Consmption of the AVR is mentioned as 480 Watts.
Can some one plz guide me if:-
1) I can use a normal 220-110Volts ($1) convertor :) (Which changes only the shape of the plugs) and does not change the Voltage to run this device in India.
2) If No, plz let me know if i would need a dedicated 220-110 Volts VOLTAGE CONVERTOR. If so, any good make/ model which is available.
3) How is this AVR3650's performance. Ignore the heavy price tag as i am getting this from a friend.
Rgds
Sreejith
