corElement
This is something thats been going on in my mind ever since I connected my 300x2w rms 6ohm 93 sensitivity jamo towers to my 1997 sony hifi GR-8 system which was specified 1500w pmpo but 90x2w rms fronts @ 8ohms and the thing drove it fine at low volumes. There was an inherant coloration of the sound which I assumed was the shittiness of the unit itself.
But if I ignore the coloration, was there any actual risk in using a mini hifi / htib amp to drive high sensitivity towers?
Lets take for example
Archived DAV-DZ570 : DVD Home Theatre System : Home Theatre System : Sony India
Just another htib, god knows what it sounds like but it specifies 140x in each channel, and from what I remember of seeing a sony speaker from htib sets at a store they were rated 3 ohms.
I dont know if the speakers are driven from the controller or the sub, but regardless, suppose I had to run my same towers on this htib worth some odd 14k, what will exactly be the fallout?
I dont know what kind of amp is on the htib sony.
I dont know what kind of connecter the htib amp/sub uses to drive its own fronts.
Basically, whats your take. I dont want it to become "you should buy something better like onk or philips discussion, I just want to understand whats the drawbacks to using an htib to drive non specified speakers which are around 90db sensitivity and the htib specifies 100watt+ on each channel ( which I dont think is accurate ).
