Ha ha.. I had made a wooden structure on ceiling to hold two passive subs, heights and provision to hold absorption on ceiling..
Wow Elangoas, you seem to have defied the law of Gravity.
Wow Elangoas, you seem to have defied the law of Gravity.![]()
It is an unorthodox position for subs.. I liked the idea of sub of ceiling, so tried it.. Love it..
Boy oh boy!! I am speechless here.
Speaker companies should hire @elangoas as a research engineer or lab rat
Raghu
is this have same bass depth as sitting in floor or corner?Ha ha.. I had made a wooden structure on ceiling to hold two passive subs, heights and provision to hold absorption on ceiling..
More pics on this thread - https://www.hifivision.com/threads/...in-ceiling-subwoofer.68753/page-4#post-800318
Well my wife is already fighting that I have occupied the master bedroom for HT purpose no way she going to agree. Her answer is if I get anything without her approval be ready to see an ad in OLXHa ha.. I had made a wooden structure on ceiling to hold two passive subs, heights and provision to hold absorption on ceiling..
Hats off to you for thinking out of the box.![]()
Sorry for OT on this thread than your views on the stabiliser..
Hi, did you get the Vertex? Any views!No worries. I am planning to go for the vertex. Ill just keep the sub on top of the stabilizer hahahaha. Let me check with the owners on the actual dimensions. I may be able to squeeze the vertex along with dual subs
Hi Mayank. I won’t be home for another 2 months. Once I return home i will be getting the vertex.Hi, did you get the Vertex? Any views!
Hi Love4sound, In case if you are going for the Vertex pls do let me know how much capacity stabilizer is required for a home theater system including a subwoofer. I am not using any power amplifier. Also does it make any noise & generate heat. I think you get Relay & Servo stabilisers, not sure which one is better.
The Vguard digi 200 smart which I have is a very inaccurate & not so smart stabiliser & was planning to go for a new one. Thanks.
They have 3 and 5kva ratings. Both have the same height and weight with a marginal price difference of 1500. 3kva itself is more then enough.
AFAIK, they do not come with any plugs at all, however, they strongly recommend a 16 amp wall outlet and thus, you will have to buy a 16 amp plug. Very highly recommended to keep the vertex as far away from the main gear as they do emit sound.Thanks, I'll check the dimensions on their website. Also do they come with 5 or 16 amp plugs ? Room space is also a constraint for me hence was avoiding a big stabiliser.
If you are planning to keep your subwoofer near the stabiliser pls check if there would be any magnetic interference.
It’s bulky but I checked with two FM’s who confirmed there is absolutely no noise during operationThanks Mayank, had already made a 16 amp socket for Vguard so no issues then. Now only the noise & size issue of vertex comes into play.
Yes. They have one model only for home theatre use.Thanks Love4sound, I am assuming you are referring to their Servo ones.
