Voltage stablizer
Anik06
Pune
I want a voltage stabilizer for my HT setup. Please help to choose. My requirements
Samsung LED : 110W
Denon : 400W
Subwoofer. : 250 W
Thanks a lot in advance.
Anik
Samsung LED : 110W
Denon : 400W
Subwoofer. : 250 W
Anik
If you are using a receiver, then you should ideally use an isolation transformer alongwith stabiliser.
If i remeber correctly Digi 200 model is 1200watts capacity.
Please check the spec possible
Servo is a good stabiliser. You can also go for Sen & Pandit. They have a long experience & goodwill.1200 watt will be sufficient for your set up.
