Vu UHD 55 premium tv with pixelight.
  • Thread starter Thread starter Deleted member 38504
  • Start date Start date
Hi, I visited croma this weekend and they run Bahubali HD clip on Vu 55, LG 55 and Sony 55. I found that vu and LG picture quality for HD was not better then my current Toshiba 32. Is it true that 4k Tvs gives better quality for full HD? or HD looks better on 32 ? or it's just my eyes limitation.
In search of finding out the answer to the question that 1080 will look better on 4k, I read below page. It seems the tv should have very good upscaling to make 1080 better on 4k tv. And if not done, it may degrade the quality. Is Vu upscaling it well? can any user give the input? Should I go for 55 " 1080 or 55" 4k ?
https://www.cnet.com/news/can-4k-tvs-make-1080p-look-better/
I am using VU 55 inch 4k TV since last 3 months. I find 1080 way better in it compared to my earlier Panasonic Viera fullHD TV. Its upscaling is very good.
This is probably some comment from a user that hasn't tried out the advanced picture settings on the TV. Try these settings. They make significant difference.
Although there are other risks with Vu UHD TVs before you consider them. My issues with it are @
http://www.hifivision.com/televisio...ark-corners-worth-sending-service-center.html
Which model is this? I don't see the option to enable Ultra Dimming and Smooth Motion Rate on the TV? I have this one https://www.flipkart.com/vu-140cm-55-inch-ultra-hd-4k-led-smart-tv/p/itmewpzfnczzgzjb
Vu pixelight UHD and Vu pixelight uhd with cricket mode have the same price...Is there any difference between the two or which one is better?
