Hi everyone. Posting here to try and get advice on repairing an old walkman I picked up. If this is the wrong place, if you know where I should ask, please do advise!
The walkman is an old classic wm 36. It seems to be mostly in excellent working order, sounds great - but one of the spindles isn't turning so the tape just winds into the machine. I've opened it up, and sure enough one of the drive belts is just sitting there not connected to anything. So, there's a chance that simply resetting the belt might get it working again.
Problem is, I can't see exactly where the belt should go. There are two belts. One is in place. The second clearly goes around the white plastic disc in the middle, but I'm not sure where the other end attaches to, as there's not another spindle with enough room for another belt. Both belts also seem very loose so I'm wondering if they need replacing.
Picture 1 shows how I found it. Picture 2 shows how I think it might go, but the spindle doesn't look like it was designed to drive two belts.
I would appreciate any advice!
