Wall Mounts for Energy Take Classic 5.1
I use the Tono systems wall mounts brought from technoguru.in site for my Energy RC-Micro. You can try from technoguru.in site as I am not aware of the site that you have listed.
Thanks Manniraj.
Technoguru site has also listed the same mounts. The site which i have mentioned is providing the mounts as a pack of 5 mounts. Besides i have checked the authenticity of the site on scamadviser and the site seems to be safe.
One more thing, how have you mounted you center channel? Have you used the same mounts for that or have you simply used the key hole provided behind the speaker?
Thanks Manniraj.
I got only a pair for my 6 and 7th channels. The center channel is mounted on my showcase near the TV. You can use the key hole to hold the speakers.
