Want a state of the art 4k home theater system
tusharpatil
Nanded, India
Hello friends. I am looking for a good 4k projector preferably laser projector.
My room size is 20 x 25 feet.
Also looking for good audio system to go with it.
I am totally noob in these things.
So expert advise is much appreciated.
Thank you.
If i were you, I'd have gone for these for home theatre -
Sony VPL 295ES (One time investment)
Marantz AV7705 (One time investment)
Diy bookshelves - kits available online (can be upgraded later)
Diy power amps (can be upgraded later)
Diy room acoustics
I recommend the below config as a first suggestion.
Epson 9400 Projector (4K Enhanced, not a laser projector)
Grandview Screen
Marantz 7705
Emotiva Power Amps
Emotiva T2+, C2+, E2 Surrounds
Emotiva A1 or SVS Prime Elevation for Ceiling
SVS PB2000 - 2 Nos - subwoofers
You can also consider SVS Prime speakers instead of Emotiva speakers.
Thank you.
With a 10L budget you can set up a very good theater. Go for pre-pro combo and avoid an AVR. Speakers you have a huge variety. subwoofer dual set up is a must.Go audition with dealers who are nearby. If you have any expert dealer nearby give them a budget of 8L and see what combos they suggest.Marantz and Yahama have good processors. Yamaha also provides a 11.2 channel power amplifier. Other well known power amplifiers are EMotiva,Rotel,Parasound,Anthem,ATI,QSC,Krell,Arcam etc. Emotiva bass x series will be the most economical and the others will be very expensive. Height and surround speakers don't need very high quality power amps. You can buy a good 3 channel PA for the LCR and get a budget 5 channel PA for surrounds and heights if you are planning for a 5.2.4 set up. If 7.2.4 then a good 5 channel PA and a budget 7 channel PA. Speakers you can check with Dali,Kef,Klipsch,Polk,Elac,Xtz and many more brands available. Subwoofer look at Rythmik,Rel,Svs,Sunfire,xtz.
That's a great budget. Before you do anything, I would advise you to visit all the Dealers in your town as well as neighboring bigger towns which have good Demo rooms. Talk to those guys and see what kind of configuration/quote they offer.
Do you have a setup currently from which you are upgrading?
MaSh
