WD TV problems ...
Spidey
India
hi
got few questions about wd tv :
1) why does it not support DVD menus in movies stored iso/vob
Also, next chapter button also does not work.. we have to manually do fast forward... can't jump to next scene...
2) Why does'nt wd tv save settins when we exit.. for ex- i choos output display as 1080 24 p , when it restarts it starts in display - auto..
3)what is the best format to save dvd movies on hdd for full featuerd playback on wd tv?
thanks
1. WDTV does NOT officially support ISO files. You are lucky that you can at least play them!
2. Your TV may not be supporting 1080p inputs. If that is not the case then try using another HDMI cable. If that still does not work, go for a firmware upgrade.
3. Mp4 at higher bitrate resulting in say 1.4GB for movie should be a good option.
