Hi got my Xtreamer Media Player (XMP) today my 1st impressions are given below all the comparisons are done with WDTV which i have been using form last 6 months
PQ almost same as Wd
SQ do
Remote of XMP is not working properly from a distance of 10/12 feet and even when in close range near player certain angels only V/s WD remote is perfect the quality of remote range has to be impoved (tried with my harmony too same problem so ir range in unit has some problems).
On screen menu is faster than WD but gets hanged sometimes and i had to unplug the unit from power and restart never had the problem with Wd maybe XMP with improve over the time with new firmware updates.
My 1TB External HDD (WD) working perfectly with WDTV is not even getting recognized by XMP the same was working perfectly with WDTV.Tryed with another 500 Gb external Hdd working properly diffrence =1tb was fat 32 and 500 gb was NTFS format (???) maybe have to reformat my 1tb hdd to NTFS
Wifi support is great esp with a free wifi Antenna- Definately a BIG advantage for XMP.another plus is copying directly to internal HDD from USB or network (tryed with external hdd but not on network.
Price (XMP)Rs.9990/- v/s (WDTV)7000/- to 7500/- payong 2490/- min more for Wifi Antenna Hdmi 1.3 internal HDD encloser depenends on requirement.
...and im expecting that XMP will have more community support as its open source so guys take your pick :clapping:
sorry for the quality of pics from my mobile phone
Remote range is really bad even with my harmony and sometimes i have to press the on button 4/5 times to switch it on..a few others in xtreamer forums have also highlighted this problem and sometimes the unit is freezing and i have to remove the power adapter to restart,may be all this will get solved in next few firmware updates...also doesn't support any MP4 file over 2 Gb just says "invalid File".and does not recoginize FAT32 HDD had to reformat my 1TB to NTFS.
maybe xtreamer is going typical NOKIA way all the experiments on end user before bring a perfect firmware.(a co-incidence that both are European Cos:lol
i wanna know about dreambox are u using it?
1> Xtreamer remote doesnt work beyond ~12 ft or so. However, I'm able to use logitech harmony upto around 18-20 ft. without any problems - I have the activities created so it brings up all the devices at the same time and it works just fine
2> I have seen it froze once, when I came out of a movie and it was not responding at all. I had to power reset - this was the only time I had to do it
3> not just mp4, any file I try to run over UPNP (I'm using Windows 7) gives me "Invalid File!!" error - this comes only when the Preview is ON, with Preview off If I try to play the file, it just doesnt do anything - this is something I want to resolve first - let me know if anyone has experienced this or know the solution - whats the right / quickest way to approch Xtreamer support for this!!
4> So far its been great in terms of PQ when I tried some demo content and hi-def content - I'm yet to play other file formats and files over 2GB and see how it works
Atlease dont belive these bidding in ebay india ... manipulators from company will show it sold at abt 9600Rs which is real price if you order xtreamer directlyXtreamer is available on ebay india and Current bid is Rs.7,100.
overall its a great unit PQ is better than WDTV and SQ is just awsome (may be a little less vol but is very good viz WDTV which i have been using from last 6/7 months)
mad , are u buying one more? hd player
Noking, can you let me know how you had analyzed it? Did u compare the same scene using WD and Xtreamer? Any screen grabs?
I am really curious to know it, bcos I am considering buying a WD or Xtreamer for my bedroom
