Wemax One Laser Projector - my journey of discovery
There are motorized/pull down projector screens with tab-tension feature, which usually keeps the screen in place using tension. Do some research and see whether it will help in your case
Investigated that. Was not able to find in India. Also, quite expensive even in the US. I had already blown my budget on the PJ. Did not have the appetite to spend on an expensive screen.
Not available on Amazon India.
Saw one on the Elite India site, but clearly states not suitable for Ultra Short Throw projectors.
I spoke to the Elite guys in India. They reccomended a fixed screen for a UST projector.
http://www.eliteadvaning.com/index.php?route=product/product&path=100&product_id=90
Fixed screens are ideal for UST. But since you are not taking the diy route you would have been better served by the same screen you have right now with the cine grey (not cine grey 3d) material. You could have traded some brightness for enhanced perceived contrast.
