Wharfedale ms100 or Polk TL1600
Santanu Ghosh
Kolkata
Room size is (15*12)sq.ft.
Movies are the primary & music secondary.
AVR- Denon 1713
I have shorlisted the following speakers:-
1)Polk TL 1600 5.1
2)wharfedale ms 100 5.1
Please help me select the best speaker from the above 2 mentioned:)
I want to demo them both but seems not possible...The Pro Fx shop at Atria Mall @ Worli , Mumbai has only Polkaudio speakers....and dont know where i can find Denon at other places...Any idea ?
sorry dude....I am from kolkata. Pro Fx kolkata has both denon and Polkaudio speakers;)
i suppose Pro FX are distributors o Denon, Polk & KEF all over india...May be they might not have Denon @ the moment..Confirm with the dealer after they have received the model & then go for audition...
Wel, i seem to have been mis-quoted.. when i said ProFX does not have 'both' , i meant Wharfedale and Polk Audio speakers...that was in reply to Aakashr's post; though i didn't quote him.
I was saying that i did check Denon and Polk Speakers but i don't know where i can find Denon AVRs elsewhere in Mumbai with Wharfedale speakers for testing
Profx typically suggest for Polks with Denon and they do go well and TL1600 have good views about its capability...wharfedalems-100-hcp appeals more as Boston Acoustics XS in form factor, sub not robust as other though us 150 w
TL1600 design is well built and put together.
Best way is to hear them to believe it.
Actually I have heared the polk TL1600 with denon which is good.But there is no way to demo wharfedalems-100-hcp.
Can anybody here please help me to choose between the two.
really confused:indifferent14:
