bikram_singh
And one more thing, do I need an amplifier as well? Or is it good enough. I may not want to spend on it unless it is an absolute must. Please advise.
The surrounds you selected should be good enough. If you have the cash and went for a higher series for surrounds, it should not cause any issues with integration but you may not get a lot of benefit for the extra dough you spent. It is important that the LCR must match, surrounds shouldn't be a such a big deal.Thanks for the link.
Do you think
one should replace Polk Audio TSx 110B Bookshelf Speaker with
Polk Audio FXiA4 Surround Loudspeaker? or it will be a mismatch to the system I've selected?
It'll be used as rear speakers
Its always better to use amplifier with more power ratings with towers.Doing this,the tower sound much better even its with 90db sensitivity.Amp controls the speaker well and you can get better fidelity.
I have checked myself with different amps.I compared Rolel 70w power amp with Rotel 100w and 100w amp had better sound stage and control over speakers.Speakers needed minimum 20w still with 100w they sounded in different and better way.One of our forum member also had Denon X1000 with Dali7.Still he went for X2000 later as he felt there was improvement.Which amplifier do you think I should go for the aforesaid system?
Thats why I told,you can go for X2000 if budget permits.It has 4k video support.
Good av amps start around 50k and more.I think I should wait and then buy X2000 only when I can. That sounds like a good idea. And how much do you think I should keep budget for Amplifier if I buy it?
@spirovious - among the current crop of mid level receivers (50-60k) which do you think has the most power? I am not sure if have a ready answer, but please let us know if you have some models in your mind.Good av amps start around 50k and more.
Budget amps claims 80w plus power but struggles when push hard.
So for tower speakers, a budget of 50-60k can be safe option.lf you plan to upgrade after few years, then go for lower models.Have you taken any Demo?
I hear Pioneers usually have high power output in a given price bracket, that's why i was wondering.If I am suggesting X2000 then,you can get in that price-
http://www.hifivision.com/surround-amplifiers-receivers/15250-avr-pricelist-67.html
Pioneer LX series are much better but costly series.Polk may sound bright with pioneer VSX series AVR.Which AVR of Pioneer you think will be comparable to Denon X2000? And is there any Marantz AVR comparable to X2000 in quality and price?
Hi folks, logged in today morning and found this juicy discussion going on!!!
Firstly, there's one aspect that nobody has touched. bikram_singh, you've said the room dimensions are 25X15X11 feet. Now we need to know how you're aligning your speakers. Obviously one of these dimensions is the height, which is not relevant here - we're not sizing for ACs The entire discussion going on here is relevant only if your viewing distance is either 15 feet or 11 feet. If your viewing distance is 25 feet, you're going to have to re-look at everything. You'll need a pair of RTIs with a receiver + power amp (I dont think the TSx will suffice). Unfortunately that'll throw your budgeting for a toss.
Now assuming that isn't the case, then this discussion (TSx and allied products) is relevant.
I have a pair of TSi 400s which is the previous year's equivalent of the TSx series. Believe me, Polks are tremendous speakers.
I've paired them with an Onkyo TX-NR 616, and they go fine.
You will need a fairly powerful receiver for your room size. I'd suggest going with Denon X2000 at a minimum (stay away from X1000). On the Onkyo side, a TX-NR 626 minimum, or a TX-NR 727.
One more piece of advice: Try to source the receiver from abroad - preferably from the UAE or Europe because they are on the same voltage as us. If you buy it from US, you'll have to spend another 5K in a stepdown transformer. Trust me, receivers are OBSCENELY priced in India. It's criminal to pay the amount they charge here in India. You'll easily cut 50% costs if you source it from abroad. Of course there are caveats like no warranty etc., but with the amount you save you wont be complaining.
For eg: I got my Onkyo 616 at 25K INR from Dubai, whereas it costed 65K here. That's the kind of savings that I'm talking about! BTW (touch wood) in the past year I havent spent a single rupee on servicing it.
Regarding subs, somebody mentioned Velodyne. I have an Impact 12, and I can assure you, its an amazing product! Playing music in my living room rattles my bathroom doors and bedroom windows!!!
Cheers!
