To start with, this is what I'am looking to replace, If I do sound a little old, That is because I have suffered 45 years on this globe
1. SONY TA-AX44 integrated stereo amplifier
2. Audio-source EQ-100 hardware 10x2 band graphic equalizer
3. An AKAI turntable ( LABEL GONE, DONT REMEMBER THE MODEL)
4. A SANSUI T-909 AM/FM tuner
5. A Pioneer CTW-208R (Well just got it, was searching for a tape deck after the Technics RS-B11W simply worn out all its small wheels inside)
SInce I'am planning to spend some money on music after 27 years , I need a good reliable system, Took a look at every SONY and Phillips showroom around first, Phillips have nothing compared to their own systems of the past, All so called Home theaters, with DVD/BD players only, No line in out and other input/output, same with SONY too, SONY website in Europe and U.S showing some stereo receivers, Then there are A/V receivers from SONY, ONKYO, PIONEER, YAMAHA, driving some, laughingly small speakers, which claim 120/110/100 watts etc (@6ohms with 1-10% THD), since I will be using these mainly for music listening, These seem to be overkill or no-value for money, Also none of these really sound sweet enough to replace the SONY TA-AX44 AND SS-S440 speaker combo, Do these so called SUB-WOOFERS, sold at thousands can actually make some good bass?, from what I heard so far, These are not very convincing at all.
Pioneer has a decent 45wx2 (proper 20-20000HX) amps like A-209R, no digital input, Badly want to use the full potential of a denon CD-PLAYER lying around, Have some YANNI and HARIPRASAD Chaurasia CDS, Now working fine through RCAs, want to try out through SPDIF
Onkyo has a good spec amp called A-5VL (Only on their website, not even available anywhere, it seems like that), It is exactly what I'am looking for, Anyone knows where and how much?
Power consumption figures are more than 200 watts for most Home theatres, well much more than what they can output from two speakers, LOL, means if I simply use these amps for three-four hours they will cost me one unit of electricity, Hmmmm ie a lot of money, so mostly these are not for constant use for sure,
excellent specs exist for HARMAN KORDAN MAS-100 and Onkyo CS-1045 music systems, Also ONKYO website says the stereo receiver R-1045 in these systems are sold separately, Anyone knows what is the cost for these babies? and where are they available
One system ( even though it eats up 250w of electricity) and a lot of features, (ie what they call the useless stuff they pack ), A Yamaha RX-V367 and coupled with some Speakers called POLK-AUDIO RM-6750 (never used those), it sounds good , Not much BASS, but great manners in mid and normal listening, Again it is a video processor (not a stereo), I really don't watch DVDS and Blue-rays. (I hate too many movies)
AN ONKYO + JAMO combo which can do all these asks for 300+ watts, Well heats more too, Since I live in Kerala, I don't need too many room heaters for sure,
The question is , what options do I have for a stereo amplifier.
Requirements are simple,
1. it should give me 45w x2 nominal, with neat stereo imaging,
2. must have spdif optical and co-axial inputs to connect my Satellite receiver, ( lot radio and music channels available on my C-BAND dish, Need to connect the optical out and listen through my amp, they do sound better than FM for sure)
3. Need to have a PHONO (MM) input and a couple of other line in, plus a tuner and tape loop
Brand is no concern, so far as it works fine , AVOID SO called HIGH-ENDS, (Better use the power saved to water my fields,That saves the earth and reduces global warming LOL), My SONY uses about 87W to power two pairs of 45W (nominal) speakers, with very good sound, If the technology has improved in the last 25+ years, There must be amps that can do the same , at least with similar power requirements.
I still use the 1970s, BONEYM music played from my turntable (NIGHT FLIGHT TO VENUS and By the rivers of Babylone), to check the clarity of music and performance of the system, Also Chiquitita from ABBA seems to be perfect for testing,
So I'am looking for some suggestions, May be someone here might have seen something else in these lines and possibly help me
THANKS in advance
THANKS in advance
