what do you think
markyboy156
kettering
hi
i have the monitor audio 8 fronts centre
and if i was to use jbl 580 speakers as rears and additional rears
would they sound great and work seamelessly intergrate well with the montor audio
8 front and centre
or would the jbl 580 be better for front and centre speakers for hometheatre and music use
priority hometheatre thanks
markyboy156,
It is very important to get the front three speakers correct and timbre matched in order to create a very pleasant music/HT listening environment. I would place the set of speakers on the front which sound best to my ear. Rear speakers are important too but it's less critical than the front and hence integration is not much of an issue.
