Yamaha SW300 [yet to be delivered]Best would be to do a subwoofer crawl to find the best placement. Which sub are you having.
Subwoofer crawl method is the best way. If you wont be able to do that based on the pic there are 4 options i can think for you to test. Right and left corner. Move your towers to the corner and place the sub in between the rack and speakers on both left and right. Please do post pics and share detailed review on how the sub-woofer sounds. It will be of great help for all who are looking for sub under 30.
Sure bro, I yet to receive the sub. Will post the detailed reviewSubwoofer crawl method is the best way. If you wont be able to do that based on the pic there are 4 options i can think for you to test. Right and left corner. Move your towers to the corner and place the sub in between the rack and speakers on both left and right. Please do post pics and share detailed review on how the sub-woofer sounds. It will be of great help for all who are looking for sub under 30.
Where should I keep the Sub woofer? Right, left or center below the AVR?
Manoj ,Yamaha SW300 [yet to be delivered]
Not yet! Just talked to the dealer, he said, it would be delivered within a week. So, Im guessing I could set it up next saturday.Manoj ,
Have you got the Sub delivered . Eagerly waiting to hear from you on the review .
I dont think thats possible, anyway, have quite a room. let me try many positions and update this threadCloser to your listening position, sides of your seat.. If that is not possible,then front corners..
Wat avr you are using?Okay, I got my Sub. And tried auto config in the AVR. Took really 5-10 Min to set it up. Played test songs from USB and found that Sub is soo under performing. Not even providing the bass and CLARITY my 5.0 has given earlier. I must have missed something for sure. Didn't touch crossover settings in the AVR. The CO knob behind the sub is set at 50s. Tried changing that and nothing. Tell me what did I miss! Suggest me guys.
It has Audyssey right? Run it first with the sub volume knob set at 50 percent. Experiment different positions and volumeDENON X550BT
Ok I just checked and seems like it doesn’t have Audyssey. You need to manually set the subwoofer distance in the speakers settings. And for a single sub positioning is everything and it matters the mostAudyssey? I don't know bro. So, position matters unlike Front speakers no matter where it placed?
yes and i have already suggested 4 positions for you to try in my previous commentOhhh. Okay I ll try diff positions. But given the cable length all I cab do is placing it at left and right positions of the AVR. (See the pic above)
