When to upgrade to new speakers
Shaishav_Udani
Pune
Hi - I dropped by Yamaha showroom yesterday.. They have got this Yamaha NSP51 and NSP350 center and surround sound speakers.. do you think I should consider upgrade to either of these from current NSP150? Or do you think adding two Yamaha music cast 20 wireless for surround would be a better deal? Really appreciate your inputs please. I have provided the specs of all these three speakers. Also to mention I'm using Yamaha RXV-4A AV receiver. So please let me know the compatibility as well
NS-P51
NS-P350
NS-P150
Type2-way acoustic suspension2-way acoustic suspension (NS-PC350) / 2-way bass-reflex (NS-PB350)2-way acoustic suspension
Center Speaker woofersDual 10cm (4”) coneDual 13cm (5”) coneDual 8cm (3-1/4”) coneTweeter
2.2cm (7/8”) balanced dome3cm (1”) aluminium dome1.4cm (1/2”) balanced dome
Frequency Response70 Hz–36 kHz58 Hz–45 kHz65 Hz–38 kHz
Nominal Input Power60 W100 W30 W
Maximum Input Power180 W200 W80 W
Sensitivity92 dB/2.83 V/1 m90 dB/2.83 V/1 m86 dB/2.83 V/1 m
Impedance6 ohms6 ohms6 ohms
Dimensions (W x H x D)415 x 135 x 167 mm; 16-3/8” x 5-3/8” x 6-5/8”500 x 174 x 202 mm; 19-5/8” x 6-7/8” x 8”395 x 130 x 127 mm; 15-1/2” x 5-1/8” x 5”
Weight3.2 kg; 7.1 lbs./unit6.3 kg; 13.9 lbs./unit2.1 kg; 4.6 lbs./unit
Crossover Frequencies2.8 kHz
Surround Speaker10cm (4”) cone13cm (5”) cone8cm (3-1/4”) cone
Tweeter2.2cm (7/8”) balanced dome3cm (1”) aluminium dome1.4cm (1/2”) balanced dome
Frequency Response69 Hz–36 kHz57 Hz–45 kHz60 Hz–38 kHz
Nominal Input Power50 W50 W20 W
Maximum Input Power150 W150 W60 W
Sensitivity89 dB/2.83 V/1 m88 dB/2.83 V/1 m82 dB/2.83 V/1 m
Dimensions (W x H x D)148 x 252 x 150 mm; 5-7/8” x 9-7/8” x 5-7/8”186 x 320 x 208 mm; 7-3/8” x 12-5/8” x 8-1/4”130 x 225 x 127 mm; 5-1/8” x 8-7/8” x 5”
Weight2 kg; 4.4 lbs./unit4.8 kg; 10.9 lbs./unit1.2 kg; 2.6 lbs./unit
Crossover Frequencies3 kHz
NS-P51
NS-P350
NS-P150
Welcome to HFV!
I am sure you will find yourself enriched with the vast experience and knowledge shared by our FMs (Forum Members) in various threads and topics. Do browse the threads which will have ready information for the queries / challenges you may have around Audio / Video equipment etc.
Happy Browsing and wishing you all the best! Suggest you check the Yamaha owners thread for possible answers.
