Rajesh_p
I'm running a pair of Audience 82's in a 250 sq ft room of a CA 540 Azure and it actually sounds pretty darn good. There were mixed opinions on the forum when I asked the same question but the CA is holding on fine at 100 x 2.
I do plan to upgrade though and will either add a power amp behind my CA or replace entire setup/
Am starting a thread on this matter
I checked and found that CA 540 Azure is 60 Watts into 8 Ohms and that is exactly the same as the Bryston 60sst...Good you are happy but if you can answer few of the below questions then I can know if I'll will be happy.
- Does it have a huge sound stage?
 - Do you get room filling experience?
 - How are the dynamics?
 - to what levels are you able to go loud wilthout the sound cracking?
 - What is the music you listen too?
What did you mean when you said CA is holding on fine at 100 x 2?
If you do plan to change your speakers do let me know....
Thank you
