Which Amplifier should i buy
mohit_ubs
Noida
I need help in deciding which amplifier should i buy. Given loads of option on the web and in the market, im confused.
I currently have two Woodstock tower speakers with 8 ohm impedance, 11inch woofers in each tower and having Peak Music Power Input of 480 Watts, which i use as front speakers. Additionally i have two Philips tower speakers with 6 ohm Impedance and Max RMS power of 65 Watts. These i have been using with a local amp, which has now konked off.
Im NOT looking for further investing into a centre speaker and a subwoofer and hence would need your expert advise on which amp to buy that can pickup the Woodstock speakers as the front ones and Philips as the rear ones WITHOUT investing in a centre speaker and a subwoofer, and still give a decent sound.
Thanks in advance
You can try the following AMPs:
Woodstock AW602 (contact suresh 011-28741353 - the number may have changed)
Norge (Mr. Bajaj Norgeaudio.com)
as already discussed by FM's here.
