Which APC UPS for only NAS or maybe HT system?
Just one more question, does this have noise one needs to worry about? Considering it'll be next to my system.
It makes noise when switched on, and again when shutting down. While on, its absolutely silent.
Unless the power goes. Then its audible - beeps. Gives you enough of a warning to shutdown your NAS.
If you have av receiver you may need pure sine wave ups, which is smart series from apc, link already posted by another member, whats your total load?
I don't own this but BR1000G-IN, so not sure about the Fan. However, as per the datasheet, it doesn't look like this unit has a FAN. But it's worth confirming probably from the APC forum since it will be the next to your system and any noise will be annoying.
