Which AV Receiver to buy from Dubai (budget ~25k)
marX
Kerala
Hi !
I want a decent 80WPC (8 ohm) AV receiver with WiFi (DLNA certified) with USB play back (1080P). It should be 5.1 with sub pre-out. I would love to have two analog (AV) and three HDMI i/p with S-video, AV and HDMI out.
Also, it should have an option to control gain of the 6 channels independently (an auto calibration option would be very cool).
Budget is flexible.
Check Denon 3313, Yamaha Aventage 2020..
Hi !
Budget is flexible.
Onkyo TX-NR 616 or 515 or Denon 2113... If you're buying from Dubai all these will fit in that budget
