Doomster69
Hi Guys..
Thanks for the inputs...Really helpful...
Decided on buying a pair of X2Ts in the next week or so...absolutely love the sound...needed help choosing an AVR to drive these...not looking to set up a pre+power amp setup. The dealer mentioned i should go for the NAD (t757) to drive these..bit i dont like the AVR - has limited options (bluetooth/wifi, etc)..dealer mentioned that something like a x2100 would keep tripping out due to load/lack of power and its preferable to have atleast a 40-60 watt dedicated channel to drive the speakers to their true potential..he's hard selling the NAD but i honestly dont like the product features...!!
as i mentioned, i need an integrated AVR solution under 1 lac...So between
Denon - X2100, X3100
Onkyo - TX NR 737
Marantz - SR6009
which ones would be a good fit? Ive read the specs but not sure what the site mentions as the dedicated wattage per channel!! As ive come to know, these no.s are usually "cooked"
I'm really keen on buying the PSBs. But if im not convinced about the AVR+Speaker marriage working out..(divorce means more money )
In fact if its such a hassle to pair up, id rather go with the Paradigm's 11's with a Denon X2100 - used the same pairing for demo, sounded great..!!
Do anyone have experience of using AVRs with a similar speaker? Would these have heating, tripping issues if paired with the power hungry X2Ts?
Big thanks to all for your suggestions!!
Onkyo - TX NR 737
Marantz - SR6009
