Hi - I need a new TV and have decided on a budget Samsung (for various reasons) but am confused over the different models. My requirements are:
* Around 42-46" inch screen (will consider larger ones), Full HD, LED, Smart, WiFi, all catchup channels, Netflix, great SD/HD picture, min 3xHDMI, responsive with good usability.
I'm not too bothered about 3D, but I'd also like a decent sound bar to accompany it (perhaps one that will also connect wirelessly to my android phone to play music).
My budget is basically as cheap as possible - 800 for both would be nice, although I will spend more if it's really worth it (i.e. newer models, faster apps etc)
--tia
--tia
