Which is the best 32' Full Hd led tv?
knight
Mysore
I am planning to buy a 32' full hd led tv. Please suggest the best one, my budget is within 45k, i am planning to go for Sony BRAVIA KDL-32NX650 32" LED TV but i heard you get a motherboard problem within 3 mnths. My other option is Sony KLV-32EX600 but this tv doesnt provide more audio options.. Please suggest a better one.
With ur budget u can go for 40''LED
Still if u want to go for 32'' inch, I would advice u to go for LG 3D LM6200 TV.
Awesome PQ quality.I have compared it with sony,samsung and other models also.Best of the lot.currently LG is giving free BD Player with it.(Diwali offer I think).
Go for it and will not regret
Choose models from Sony/Samsung..anyday got superior pic quality than any other brand.
With 32 inch you can go with EX550..a semi HD model or EX650..a full hd model..at 32 inch it makes no difference whether it's semi hd/full hd.
surely no full hd at 32 inch.
does not make a difference.
also think again will you be satisfied witha 32 inch and wont upgrade...if yes fine.
otherwise get a 40 incher.
for led sony
for plasma panasonic/samsung........
you will get 42 incher plasma at about 37k..even there is a low res model from samsung at 33.5k 43 inch..but remeber res is only 800*450 range.......why settle in 32 inch.otherwise for a 32 inch there are sony models at 28k.........i think there is no sony semi hd models....check it.demo samsung also...take what you like best
however plasmas do have theier own drawbacks in spite of having superior picture and less price...like image rention maintanace..consider all points..
best of luck
