which one is better for 3D Avatar - from Jammu
drmfoley
India
Hello
I am planning to travel to Delhi (or near Delhi) from Jammu for just seeing Avatar in 3D. If you have seen it in 3D, would you suggest it? and where should I go Odeon Big Cinema or any PVR in Saket or Big Cinema in Noida? Which one is best for seeing 3D.. I have heard that some cinemas just show some 3D clips (not full 3D movie), so was wondering, which one is better.
Or IMAX Hyd. if it is worth?
DRM.
hyd Imax will be the best bet , but definetly watch it in 3D , i have seen both, prefer the 3D
Thanks Subhas.. you saw it in IMAX or normal 3D? and if you know how much difference in screen size of IMAX screen than normal multiplex screens ?
