which one is better?
yugendranath
guntur
I am planning to buy a Samsung 4k 55inch TV but confused about what to buy between nu8000 or ru7470. Should I buy a 2018 model nu8000 which is an 8series or should I buy the 2019 model ru7470 of 7series,, as there is no 2019 model 8series?
Which city are you still getting NU8000? Can u check if 65 inch option is available there as its not available in bangalore?
Its a good tv compared to RU 7470 for sure specially aesthetic wise...except the new features picture quality should be better in old one as i haven't got to compare next to each other but ry7470 is just very bright and over saturated colours i felt....the green grass felt fluorescent green when i had opportunity to compare side by side with 65inch LGSM8100.
n
nu8000 is a better tv.its even better than ru8000 which is 2019 8 series model.check here
