Hi everyone,
I am going to audion Dali Zensor 3 based on my research and recommendations by various dealers. The kind of music I am mostly going to listen to is Classics, Hindi OST for 70% of times, Jazz and Rock for 30%, via Fiio X1 as the main sound source. I will also keep them plugged with TV to watch movies on Netflix (may add a subwoofer later, if required).
I already auditioned Zensor 1 but was not impressed with its high range and bass response. However, heard that Zensor 3 are miles ahead than Zensor 1.
Here I need your great help to decide the right amp within the budget of Rs. 60,000. I was getting lured of getting an AVR (to get 5.1 in future) but it seems it's a compromise when your main purpose is listening to high fidelity music.
I also need your help on deciding the right kind of under stereo category also like a pure stereo amp without any digital interference e.g Marantz PM6005 or the one with Bluetooth, USB support e.g Yamaha R-N602.
Some of the AMPs I shortlisted are:
Onkyo A-9010, Rs. 29,000
Cambridge Audio CXA60, Rs. 63,200
Marantz PM5005, Rs, 36,000
Marantz PM6005, Rs. 50,000
Marantz PM6006 Integrated Amplifier, Rs. 32,000
Yamaha R-N602, Rs. 40,000
Kindly share your choice on above and please add if you have any other better option.
Please also share your thought on after sale service (heard Yamaha is the best). Above prices are from Amazon, hope it's safe to buy from there.
Hi Prish....
If you want to listen to classical, old Hindi and rock, then please bear in mind, that these recordings especially the old ones are on the bright side. So we need a system that has to be warm sounding, to take away this brightness. Plus if you are sitting in a room with bare walls, and minimal furnishings it will again add to the brightness.
So unless you are completely sold on the zensor 3, I would advise to try out different speakers from warmer brands like Qacoustics and wharfdale. However, if you are already sold on the zensor 3'S, then you need very neutral or warmish amps. The zensor 3 are capable of some amazing bass, so I would ideally add a arcam integrated amp to bring out that punchy presentation..
By the way, there is a pair of pmc db1i golds on sale in our forum..They are in a completely different league to the zensor's or the Qacoustics. I have heard them a lot of times in the sellers place. And they are awesome. Very very tiny, with awesome scale, great bass that belies their size , and highly detailed. It took a ATC SCM11 to match them. And the ATC is well upwards of the 1L.mark..So please give it a thought.
