iaudio
Try and get the Soundmagic E30, it should satisfy your requirements.
Grubyhalo, Thats a tough call, 'cause I have very little experience with 'buds in recent times. esanthosh, on the other hand, has a fair idea of whats good among earbuds. I have heard a lot of good things about Yuin, but most models are quite expensive.
If money is no object:
The Final Audio Design Piano Forte X-VIII Earbuds Will Blow Your Mind | Incredible Things
If budget can be exceeded, what are the other options?
I looked at Pl30 and did not like the look. It was not far away from my budget, IIRC, it was available for somewhere around 1800
Any opinion on soundmagic es18. Some give it double thumbs up and some trash it.
If there is not much option I will continue with sennheiser pmx-80
ritchie, Are you not comfortable with IEMs?
