Which TV to buy- 32CX520 or 32EX520?
yuge
chennai
1) 32CX520 - Have everything which is in EX520 but not LED..
Price is also doubled up if i go for EX520..
2) 32CX520 is better than EX400.. but it is CX series and later one EX series..
CX is the prior one to EX right? if so why EX400 lacks in lot of features..
3) What about the warrenty & service in india if i buy it from singapore..
My budget is <30K.. I prefer SONY.. All suggestions are welcome in that budget..
Thanks..
pickup the cx520 which is much better than the ex400. the c and e are just the model codes named by sony. The only diff. Between cx520 and ex520 is the latter is led. Practically you wont find an iota of difference except power consumption so better go with the cx and save some penny for a good media player
If its from singapore you forget about warranty. So i suggest u to get it from local grey market where the price will be equal to singapore price more or less...
The CX520 is far better than the EX520 from picture quality perspective. I compared in two different locations with the Spears and Munsil callibration disk and the CS beat the EX by a mile.
So only buy the EX if the power consumption or the thinness of the panel matter to you.
Hi Kittu,
My friend is on the lookout for a 32" smart LED TV. Which one do you recommend???
Denom,
The only LED tv I liked was LG LE 8500.... None of the new back lit LED tvs impressed me any better than the OLD CCFL LCD tvs. More over those fancy bezel designs and too much reflection....
If your friend still wants smart tv with 100hz ratio, I guess samsung D59xx series meets all the needs, you can even consider the LG32LV3730 series.
Agree with Kittu on LG's LV32LV 3730 (2010 release), it's an awesome TV and found it better than the likes of Sony and Samsung in the similar range.
Few days back, we bought LG32 LW4500 (2011 release) for one bedroom, the sheer 2D picture quality, clarity bowled us over.
We demoed the TV's for more than two hours in the store with various settings so as to make right comparisons. The IPS panel with wide viewing angle also helped in making the decision. Regards.
Denom,
Whats the best pricing of the TV's you've mentioned?
Also Wat about samsung D5000, sony ex520, samsung D6000??? ALso their pricings?
TIA
Went to hypercity today & found the price of LG 32" 3730 @ 44k, so definitely now know that the best price will be around 7-8k lesser than this. Wat say Kittu & others????
