Which TV to buy ?
rydraj
Hyderabad
I'm going to buy a TV but I need help in deciding which one...my main use would be use it with Tata Sky DTH and stream movies from WDTV Live (most of them 720p).
Choices;
3D Plasma
Panasonic VIERA TH-P42GT20
Samsung PS51D550
2D LED
Samsung UA40D5000PRMXL
Sony EX520
If the price difference is minimal, I'd rather go for Plasma 3D rather than 2D Plasma or a 2D LED.
I heard that Passive 3D has less viewing angle and less PQ compared to Active 3D (hence I didn't opt for one), how much of a problem is it ?
If not much, could anyone please suggest a good Passive 3D TV in my range ?
My max budget is around Rs 60K, so please suggest one.
Any other models are welcome.
Also, any disadvantages of opting for Plasma besides high power usage ?
For the budget mentioned above(60k max), Samsung PS51D490 (around 55k) will be the best bet.
Again depends on the viewing distance....if it is more than 12ft...no need to shell extra money for Full HD PS51D550....
Samsung PS51D490 has 1366x768 which is better and future proof too.....If 3D is in your consideration then nothing less than 50 inch will keep you satisfied (personal experience with PS43D490....3D seems to be small)
