WiFi Android remote for Marantz
AV55
Hi, I have been using marantz android wifi remote downloaded on my Samsung Note-2 mobile. This application is very much unstable and most of the time it does not recognise my AVR 7008- it just hangs.
Any suggestions for alternative android wifi remote application for Marantz? Please help.
You are right that I should try a fixed IP instead of DHCP but I find that to be an expensive solution specially when I don't run a server or a website etc. If fixed IP is the only solution than I might have to do it.
