Xiaomi to launch Mi TV Q1 75" on 23rd March - QLED, 192 Zones, 120Hz
For each mode you can have different settings and it changes depending on content being played. If its showing Movie, means its in HD or lesser content quality.
The mode adjusts the picture settings, colour etc - it has nothing to do with quality being input/output.
And my main point was that I have everything in the same mode, but some of the advanced options aren't available when going in to the picture settings of an input device, whereas they are when in the TV's main UI.
Try pressing the volume + button on the TV remote once.
Doesn't do anything for me as the TV is forcing the mute so that audio is only being passed to the eARC output.
I now have the additional issue of that I had turn off CEC (which also affects eARC) so that I could access the picture settings when using an external input ... so now I don't get eARC if I happen to go back to the TVs' UI. It seems I have the choice of either having access to settings or having eARC work properly and not both.
I get the same mute icon but pressing the Vol + button removes it.
Reg. Picture settings while in external input mode, long pressing the mi button on the remote brings up settings menu. It allows access to all settings without having to return to TV mode.
Long-pressing the button does nothing for me.
If you are using the built-in App, then TV becomes very sluggish. You can try with pausing the video and then press the MI button and keep it pressed for 4-5 seconds.
I'm not experiencing sluggish-ness, nor am I using the built-in apps. The issue is that when CEC/eARC is turned on, I can't access settings etc as the remote doesn't work correctly with an input device on (an Apple TV in my case).
I too have CEC/ARC on, the only difference I see is that you have eARC enabled. Long pressing mi button always brings up the settings screen on my TV irrespective of input mode currently in use. I am wondering if your remote is faulty or needs new battery. Or may be some region specific software bug.
It definitely doesn't work on mine. The button works fine when using the TV UI, but when using an input source it doesn't (seems to be a CEC bug or something region specific for some reason).
Congrats for your purchase. Where did you buy it?
Mi.com, but Flipkart has more discounts available sadly, and it was not deliverable to my location, so I ordered it from Mi.com. Life is all about enjoyment and experience, so I just purchased it with a 5000 discount.
congratulation.....goof that finally you could get one . Let us know your initial impression once it is installed
Sure, right now, the only concern is the ARC issue. Also, @vikrantxtrad, Kindly suggest to me where I can buy an extended warranty?
You have to change that setting once.. Once its set to HDMI 2.1 you enable CEC and enjoy
