Xiaomi to launch Mi TV Q1 75" on 23rd March - QLED, 192 Zones, 120Hz
Yeah it will. Firestick does not belong in an avr set up. Dynamics in sound stage is very poor in the firestick. When I tested it in my set up I had to use -10 to -15 db to get the same level of volume that I get in a Bluray player or shield or Ps4 at -25db. Even then it felt compressed. I am sorry to say that firestick is garbage in an avr set up.
How is the internal App compared to FS and others?
Nice set up. It’s sad to see that you are using firestick in an avr set up. I got rid of it within 1 hour of usage and it’s the worst device I have ever experienced in my chain. Audio is very much compressed and defeats the purpose of using an avr. If budget permits look at Apple TV or shield if local playback is important.
Thanks for your reinforcement. Yes, I do have plans to get shield pro. Only question is when.. will there be a 2021 Shield pro? That's what is holding me to pull the trigger
Nvidia has released 2015,2017 and 2019 so one in every two years. But there is no assurance they will release one in 2021. But if you can get your hands on 2021 shield go for it. Apple TV is better as per owners feedback for ott alone. Shield main advantage is Kodi and local playback.
By theory you are right but practically No that’s not how audio works in certain cases. For example take bitstream.
My hunch is the Exo Player, which most of the FireStick Apps leverage for playback, has some role. I have to super cheap Roku, and it outperforms FireStick in every possible way (Tested with Hulu/Netflix/Apple Tv+).
That might definitely be the case. However, if ExoPlayer is responsible all android based media players will have this issue, including the shield.
That got me thinking that probably it's a combination of the Player and the Audio framework; Shield uses stock Android (TV), whereas FireStick is on a customized version of Android.
Actually I found the issue. Android downsamples everything to 24-bit 48KHz and hence can't bitstream high resolution HD audio to anything. You'll need to use custom firmware (Tidal uses it) to fix that, and ExoPlayer definitely doesn't.
Since firestick won't be bitstreaming, there will be a transcode happening which will lower the quality depending on the algorithm used.
By theory you are right but practically No that’s not how audio works in certain cases. For example take bitstream. A 5k Bluray player also can bitstream compared to a blu ray player like oppo that costs 1 lakh and the decoding is done by the avr. But people who have all compared it side by side can assure you the difference in soundstage is huge between a 5k blu ray player and oppo. I am also stating the same after doing side by side comparisons with Bluray player,ps4. Let firestick output digital audio the same way shield or any other devices. The output is just not the same. If you can test and confirm I am all ears. Also the OTT performance was better in my ps4,Bluray player compared to shield. Another fm recently sold his shield since his Xbox was better for OTT. In an avr set up firestick is just not meant to be. Sorry Mi owners didn’t mean to de rail the thread. Just suggested the other fm based on my experience
Based my personal experience with both FS and Nvidia, it is not just the audio but even the HDR performance of FS is quite poor compared to the latter.
I understand the argument that bits are bits in digital domain but the reality is that there is difference between the two.
Exactly. It’s not that others here aren’t aware of the technical details. I have done enough side by side comparisons and shared my feedback. There is no need for me to explain technically and waste every ones time when I can just finish it in one sentence that FS is crap in an avr set up. I know a lot of other fms who also stated the same and moved to other devices like Apple TV or the shield. Even a blu ray player is a better choice in an avr set up as most players now come with Netflix and prime app. I have no interest to argue with anyone that I know better. I am here in this forum sharing my gears and how they perform in my room so others like me can benefit. I don’t want to waste time taking about things I don’t own. Any one can do that. That other fm set up is really good looks beautiful as well.So I just advised him to move from fs which is absolute BS in an avr set up
Here is another clue..
It's a fairly buggy device and Amazon can't be bothered to fix it. Even basic things like framerate/res matching only work on 2 apps. I've mentioned about the bugs multiple times in the past.
Then again it's a 3000 rupee device so can't fault it too much. If you can afford it, there are definitely better streamers out there like Apple TV 4k which also has Infuse and direct play for SSA subtitles on Plex.
Component quality has nothing to do with digital audio or video.
Can you elaborate on this?
Component quality has everything to do with delivery of digital and analog audio and video. A lot of TV's (can't comment on the TV being discussed here) have their internal processing hardware built around Rasberry Pi or similar base boards. We know how well that works!
What you are suggesting also means there is no difference in a product using Nichicon or Keltron cap.
Firestick outputs digital audio, and digital audio should sound the same unless some transcode is happening. There will only be a difference if you play HD audio(like Dolby TrueHD) which firestick can't handle. Everything else will be bitstreamed to the AVR.
Netflix/Prime etc only use Dolby Digital Plus, which will be bitstreamed from firestick. You should check if the settings were correct and it was getting bitstreamed or not.
Netflix has ATMOS content that Firestick 4K doesn't support.
TBH FS4K is more of a makeshift arrangement in the entire chain. MI's apps is way better.. TIDAL on MI provides ATMOS music, while FS 4K doesn't. That's a different that MI's app is unstable and buggy.
Shield Pro 2019 doesn't have gigabit port and HDMI 2.1. Apple TV 4k doesn't have Kodi and is better for people who have invested in Apple ecosystem.
So, the current compromise is to use mix of MI TV apps and FS 4k.
BTW, Tidal and Kodi works very well on TV app.
This is a surprise.
I can understand using a Blu Ray player or PS4 over the TV based App.
Better than a shield is a hard sell for me atleast.
The difference I noticed was not by a huge margin between the shield 2017 and the PS4 or the Bluray player. I have sold both the Bluray player, PS4 and very comfortable with shied pro 2019. Firestick for sure was absolutely horrible among all these devices and doesn’t belong in an avr set up
