Xiaomi to launch Mi TV Q1 75" on 23rd March - QLED, 192 Zones, 120Hz
Also I am facing a lot of motion blur while watching Cricket matches from Sony Liv app any suggestions regarding, how to control motion blur.
UI is working without lags as of now. But i can see pixelation, it's there sometimes and absent sometime during the same scene. Even when dolby vision logo is present.
All of these point to a poor internet connection, and not an issue with the TV. Move the TV closer to the wifi router, or move the router closer to the TV and try again. To debug, install a network speed monitoring app on the TV and run a speed test from there. It should clarify on the network issues (if any).
Just installed the TV, can someone please tell me the best picture settings.
1080 content don't look that good though.
Is it same with all the panels or is there a problem with mine in particular.
PS: How do I check my TV's manufacturing date.
Try a 4k video from YouTube. If it runs at 4k , no issues with your net speed.
If YouTube videos have a issue running 4k content and revert to lower resolution, use the hotspot on your mobile as the wifi connection and again try youtube 4k videos.
If ok then dont worry as sony liv has a history of poor signal quality.
Basically check your tv with YouTube 4k videos , unless you have a 4k blueray player , then you have more options.
Sports on Hotstar and Sony Liv will have motion blur. I also have same issues. I now use DTH only for watching sports and i have not experienced any motion blur
Ok, for your info, watching live telecast over internet even in a leased line would have some latency and subsequent blurs. We have a very slow intercontinental gateway for internet hop speeds. People around Mumbai may have faster connections maybe to some extent. So no TV can help you there.
An update on the pricing front:
Chanced upon this offer on Flipkart till today: Partner Offer Get additional 4% off on this product
This combined with 5+2K off on HDFC card has resulted in net price of 1.16L for today.
What happened to ARC and eARC problem when connected to avr? Is it solved... Should I take this tv to use for marantz sr 6015 avr? Will eARC work with this tv and this avr? Will there be handshake issue?
Summary - eARC seems to be working fine with newer receivers. If someone else in your city has bought the Mi 75 (or there's a Mi showroom close by), see if you can take your receiver over to test it out before buying.
You are unlikely to run into issues with the modern AVRs supporting eARC. Infact I can recall somebody confirming a Marantz AVR with ARC only was working fine. I had dig deep into this issue and seems like mostly Yamaha receivers have this ARC handshake issue. If you are looking at Atmos setup , suggest to validate the AVR compatibility (more so if it doesnot have eARC). Else any old receiver with optical should do the job in case ARC is not working.
Internet connection is working fine. I am running 4K videos on yoube.
I understand it is Sony liv problem then.
On a different note, I tried several screen tests available on youtube and the my TV did not perform well, especially the banding test.
It completely failed the banding test. There were huge pixelation and rings between colours and it looked really bad. I ran the test on standard settings with all extra features like luma n local dimming off.
Moreover I can see a vertical light or band in the middle of the panel on a black screen and vignettes on the edges on a white screen, will it be a problem in future?
Has anyone tried these tests? How do you guys consider the colour handling of your panel? Should I notify MI regarding this?
It will be printed on the box.
Which video are you testing with. I dont see any on mine.. please escalate to MI.
I have attached the pic for reference. If you can see a vertical band like thing.
If you haven't already, If you can kindly run a color banding test from youtube and share your result. It can help me identify if my panel is faulty or not.
MI advertised so much about wide color gamut and motion handling coz of 120hz panel. But For my panel, the color handling is very poor and motion too. One of my main point to buy this was 120hz refresh rate as I watch a lot of sports.
But my TV is performing really poorly.
Reading all the good reviews everywhere and in this thread also, I am thinking, is my panel faulty? Or is there something I am doing wrong?
I don't see any issue on my TV
You better complaint to MI
That's extremely normal for local dimming no? Looks like regular blooming to me.
Turn local dimming off and you'll see that the whole screen will turn grey now just like around that loading bar.
This is also something I've recently noticed on mine - although I have 3 vertical lines on the screen when displaying very dark grey-scale screens (on all content - iTunes media, Apple TV+, YouTube, Plex etc).
