Just want to update the ownership experience.
This sub made a world of difference in my movie experience. The biggest selling point of the sub for me was the sound tuning options. It has 3 equalizers and 4 port tuning options. That gives you a possible 12 combinations of settings and makes the bass management a little time consuming but well worth it as we get to tune the sub performance to our liking and also easier to calibrate it to blend with our room and speakers. My set up is in a bedroom and hence due to the limited space no matter how much of a good sub i get i had trouble with lot of rumble, vibrations and at times to boomy. The xtz has an equalizer which states "Is a direct countermeasure to the “muddy” bass problem of over represented low bass/room gain. By lowering the bass extension, the bass will be more controlled". And boy oh boy it got rid of most of the rumbles, vibrations and doesn't let the sub go boomy. Also the bass is tight and very powerful.It also has XLR, XLR-Passthrough connections and at this price not sure any subwoofer provides this many features. The build quality of the sub is top notch and also small compared to other subs of same size. Easily xtz 10.17.12.17 and the edge variants are a better choice then the svs 1000 and 2000 for sure being in the same price bracket. It may not go low as the svs 1000 and 2000 but easily beats in-terms of power and features.
