Yamaha HT 292 or Onkyo HT-S3300 or HT 5300
dolby_dts
Hyderabad
Guyz the price of Yamaha HT is around 22K in HYD Reliance Digital
and no idea abt the Onkyos :(
could please suggest be the best one to go for :D
10*10 is the dimensions of my room
I think 5300 > 3300 > 292
Don't even consider 292.
3300 may be okay for the price.
At 5300's price point, you may be able to get better setups.
May i know the price of 5300 and 3300 in Hyderabad or Approx price :D
3300 is 23K in bajaj showroom panjagutta, book now to get diwali lucky draw coupons, and fresh stock is arriving on 16th, i booked by paying 1000rs :), can also do it by 500rs.
any other Setups other than HTS 3300 Onkyo for the price of 25K max :)
for 25 k budget 3300 is the best bet. I'm in the same decision phase as you. I have a budget close to 30k and that is where all the confusion is creeping in. you will get HT 5205 for 29k-30k though!
Harman + JBL is possible within 25-30k from jblindia.com or indiajbl.com whatever it is.
Other than that, Onkyo is the only come in the same league, and perhaps some high end Philips.
Onkyo HTS3300 is real VFM under 25k. I bought it a month ago and totally satisfied. Mind you, its an entry-level htib so pls set the expectations right to avoid disappointment :-).
