Costs around 25-26K. Details are as under.....
Fully Equipped Home Theater for High-Definition (1080p) Video
Sources with Digital Music and Gaming Options
Progress is constant with Onkyo packaged home theater. Thats just what youll find with the HT-S3200 5.1-channel receiver/speaker
package, which offers more breakthrough technology than ever before at the entry level. With HDMI
pass-thru for high-definition
video, this is a convenient solution that allows you to enjoy Blu-ray Disc, DVD, broadcast, and gaming sources. You can partner this
package with whichever display suits your budget and achieve truly performance-driven home theater. Enjoy the benefits of tailored
audio performance via a full suite of Audssey technologies, including Audyssey EQ, Audyssey Dynamic EQ, and Audyssey Dynamic
Volume. You can even integrate an iPod or MP3 player via a front-panel input, or take advantage of Onkyos new DSP modes for
gaming: Rock, Sports, Action, or Role Playing Game (RPG).
HT-R370 5.1-Channel A/V Surround Home
Theater Receiver
120 W/Ch at 6 ?, 1 kHz, 1 Channel Driven, JEITA
DTS, DTS Neo:6 5.1, DTS 96/24, Dolby
Digital, Dolby Pro Logic II
192 kHz/24-Bit DACs for All Channels
3 HDMI Inputs and 1 Output for Video
HDMI Pass-Thru* (Version 1.3 Compatible with
1080p, Deep Color, and x.v.Color)
Audyssey EQ for System Equalization
Audyssey Dynamic Volume to Maintain Optimal
Listening Level and Dynamic Range
Audyssey Dynamic EQ for Loudness Correction
Front-Panel Audio Input for Portable Devices
4 DSP Modes for Gaming: Rock, Sports, Action, and
HDTV-Capable (720p/1080i) Component Video
Switching (2 Inputs and 1 Output)
3 Digital Inputs (2 Optical and 1 Coaxial)
3 A/V Inputs and 1 Output
Video Output (Monitor)
3 Audio Inputs and 1 Output
Headphone Jack
H.C.P.S. (High Current Power Supply) Massive High
Power Transformer
Optimum Gain Volume Control Circuitry
Music Optimizer for Compressed Digital Music Files
A-Form Listening Mode Memory
Non-Scaling Configuration
Late Night Mode (High/Low/Off)
CinemaFILTER
Theater-Dimensional Virtual Surround Function
Direct Mode
Speaker A/B Drive
Banana Plug-Compatible Speaker Posts for Front L/R
Channels (Speaker A)
Color-Coded Speaker Terminals
40 FM/AM Random Presets
Crossover Adjustment (40/50/60/80/100/120/150/
200 Hz)
Compatible with RI (Remote Interactive) Dock for
the iPod
A/V Sync Control Function (Up to 100 ms in 20 ms
Steps)
Full-Function RI (Remote Interactive) Remote
Control
*A separate audio connection is necessary to process multichannel audio.
HTP-370 5.1-Channel Home Theater Speaker
System
SKF-370 Full-Range Bass Reflex Front Speakers
8 cm Cone
Max. Input Power: 120 W
Gloss Finished
Magnetically Shielded
SKC-370C Dual-Drive Full-Range Bass Reflex
Center Speaker
8 cm Cone x 2
Gloss Finished
SKR-370 Full-Range Bass Reflex Surround
Speakers
8 cm Cone
Gloss Finished
Note: All speakers feature a gloss finish, an impedance of 6 ?, color-coded
speaker terminals and cable, and wall-mounting capability.
SKW-370 Bass Reflex Subwoofer
20 cm Cone
Max. Input Power: 130 W
Down-Firing
Color-Coded Speaker Terminals and Speaker Cable
HT-S3200 5.1-Channel Home Entertainment Receiver/Speaker Package SILVER BLACK
HDMI
Pass-Thru* for Connecting up to
Three Video Sources for Output to a
High-Definition Display
The HT-S3200 takes up to three HDMI video inputs
from sources such as Blu-ray Disc players, DVD
players, gaming consoles, and set-top boxes, and
delivers the output to a compatible high-definition
display. Video is passed in its native resolutionright
up to 1080pfrom Blu-ray Disc, PlayStation
games, or HD broadcasts.
multichannel audio.
A Suite of Audyssey Technologies for the
Ideal Listening Environment
The HT-S3200 has three Audyssey technologies to
help create the most suitable listening environment
for your home.
(1) Audyssey EQ for System Equalization
Removes much of the distortion caused by speaker
enclosures and the typical room environment;
Produces far superior sound than on comparable
products that lack correction capabilities.
(2) Audyssey Dynamic Volume
Maintains the desired listening level for all content,
while optimizing the dynamic range.
(3) Audyssey Dynamic EQ for Loudness
Correction
Solves the problem of deteriorating sound quality at
lower volumes.
Four Game Modes for More Thrilling
Action
A new addition to Onkyo home theater, these four
gaming modes create an experience with more
realism and impact. You can select from Rock,
Sports, Action, or Role Playing Game (RPG) modes
to match your gaming content.
Convenient Front-Panel Audio Input for
Portable Devices
You can connect an iPod or other MP3 player to
the A/V receivers front panel for playback. Your
players compressed digital music files receive a
quality boost thanks to the HT-S3200s Music
Optimizer technology.
Music Optimizer to Support
While MP3 or AAC files may sound fine on a
portable digital player, the limitations of these
compressed files can be exposed when played back
through a home entertainment system. Onkyo has
designed onboard Music Optimizer technology to
improve the quality of the compressed audio signals.
Compressed music loses a substantial amount of bit
information at higher frequencies, so the Music
Optimizer technology works to overcome this
limitation and enhance audio quality.
SPECIFICATIONS
A/V RECEIVER
Amplifier Section
Power Output
Front L/R 120 W/Ch (6 ?, 1 kHz, JEITA)
Center 120 W (6 ?, 1 kHz, JEITA)
Surround L/R 120 W/Ch (6 ?, 1 kHz, JEITA)
Subwoofer 120 W (6 ?, 1 kHz, JEITA)
Dynamic Power 160 W (3 ?)
125 W (4 ?)
85 W (8 ?)
THD (Total Harmonic Distortion)
0.08% (1 W Output)
Damping Factor 60 (Front, 1 kHz, 8 ?)
Input Sensitivity and Impedance
200 mV/47 k? (Line)
Output Level and Impedance
200 mV/470 ? (Rec out)
Frequency Response 20 Hz50 kHz/+1 dB, -3 dB (Direct mode)
Tone Control 10 dB, 50 Hz (Bass)
10 dB, 20 kHz (Treble)
Signal-to-Noise Ratio 100 dB (Line, IHF-A)
Speaker Impedance 6 ?16 ?
Video Section
Input Sensitivity/Output Level and Impedance
Video 1.0 Vpp/75 ? (Component)
0.7 Vpp/75 ? (Component PB/CB,PR/CR)
1.0 Vpp/75 ? (Composite)
Component Video Frequency Response
5 Hz50 MHz (-3 dB)
Tuner Section
Tuning Frequency Range
FM 87.5 MHz108 MHz
AM 522 kHz1,611 kHz
530 kHz1,710 kHz
FM/AM Preset Memory 40 stations
General
Power Supply AC 220240 V~, 50/60 Hz
Power Consumption 440 W
Dimensions (W x H x D) 435 x 151.5 x 328.5 mm
Weight 9.1 kg
SPEAKER SYSTEM
Speaker Type
Front Full-range, bass reflex
Center Dual-drive, full-range, bass reflex
Surround Full-range, bass reflex
Subwoofer Bass reflex, passive
Drivers
Front 8 cm cone
Center 8 cm cone x 2
Surround 8 cm cone
Subwoofer 20 cm cone
Frequency Response
Front/Center 80 Hz20 kHz
Surround 80 Hz20 kHz
Subwoofer 30 Hz150 Hz
Output Sound Pressure Level
Front 82 dB/W/m
Center 82 dB/W/m
Surround 81 dB/W/m
Subwoofer 82 dB/W/m
Max. Input Power
Front/Center/Surround 120 W
Subwoofer 130 W
Nominal Impedance
Front/Center/Surround 6 ?
Subwoofer 6 ?
General
Front 101 x 273 x 121 mm
Center 273 x 101 x 106 mm
Surround 101 x 175 x 116 mm
Subwoofer 295 x 414 x 299 mm
Weight
Front 1.0 kg
Center 1.4 kg
Surround 0.7 kg
Subwoofer 6.9 kg
CARTON
Dimensions (W x H x D) 537 x 758 x 414 mm
Weight 24.5 kg
