Yamaha ns333 bookshelf speakers
Kevin
Chennai
I am planning to buy yamaha ns 333 as those are less powered 60w 6 ohms as I am using a entry level amplifier vsx924 pioneer? Pls suggest and your opinions.. basically I do hear music's than movies? Will this speakers be good for musics and songs ?
Pioneer VSX 924 isn't an entry level AVR.. It is a 7.2 AVR.. And only 2 channels driven it should pump close to advertised specs comfortably..
The speakers are 87dB efficient and rated at 6 Ohms.. Should be fine pairing them with Pioneer VSX 924, for a modest room size of upto 150 Sqft..
Thank u will these speakers be good for musics ?
Welcome to the forum! Good luck with your search.
