Yamaha YHT 299 or Onkyo HT S3700
kannapi
kerala
guys help
both of them looks comparable on paper and pricing ..
which one is better
pls tell me advantages
consider the resale value too please
depends on what you use the HT mostly for
If you use mostly for watching movies and occasional music then go for Onkyo
or if you use it for both movies and music equally then go for Yamaha
Hope that helps.
Thank you
guys help
which one is better
Specs wont mean much. It will be easier to go and check with your favourite movie and music disks.
Its hard to judge just by reputation and specs.
Resale value of htib is quite low in comparison with separates.
I have not heard Onkyo HT S3700 .
YHT 299 is good setup ,clear n crisp sound .It has an active sub which is an advantage over the onkyo HT S3700 .
Heard other Onkyo HT .It is a kind raw power sound which is very good for movies.
