I am desperately seeking to buy a home theater system under 75K including avr. i am too confused which one is the best in that price range. I have come across Heco ambient 5.1A which sounded fine. However i need an advice.
Any idea whats the cost for definite technology pro cinema 600
Hi vIvan,
you had mentioned that you heard some pioneers are you sure those are the pioneer andrew jones spfs52 floor standers, even i have heard the 823 mkii which is absolutely horrible, the andrew jones series is highly rated by audiophiles and critics, but hey at the end of the day you have to purchase what pleases you, i have heard the wharfedales(not sure if they were the Diamonds) back in the UK they are a bit laid back speakers, good luck with your quest even im the process of setting up a home theater with exactly the same budget. The best thing is that since you are in mumbai you have lot of options make good use of them, take the effort to go to as many shops as you can carrying your favorite music/movies an audition as many speakers as you can, and do keep posted on the review of different speakers that you have heard
Sujith
Hi sujit, I have not heard andrew jones yet. I know some one who has it, I will take and audition next week. the new diamond 100 series from wharfedale has some good reviews; will do the audition next week.
Hi Poppy, not heard the dali yet; however many say that the high end speakers are better; i recon that must be over a lac.
