Which is better? Hisense U6G vs VU GloLED (Please help)
Which is better?
  • Total voters
    18
shrey75
Hyderabad
I’m confused between Hisense U6G and VU GLOLED (55 inches) please help me decide!!
For now, I will use this TV in my living room. I'll use it in my bedroom after a few months when I buy a Sony X90k
FYI: FOMO:
Last night, I ordered VU GLOLED (55 inches) from Amazon for 34k.. should I cancel the order and go with Hisense U6G?
U6G PROS:
VA with FLAD, and QLED with 700nits panel
U6G CONS:
  • no eARC (I don’t think this is a deal breaker)
  • no HDMI 2.1
  • other gaming related features
  • only 2 years warranty (no extended warranty options from Hisense)
VU GloLED PROS:
  • Price (34k is a steal)
  • Newer Model
  • Option to extend the warranty to 3 Years
VU GloLED CONS:
  • No FLAD
  • Not a QLED Panel
  • VU model does offer extended warranty options of up to 3 years. Heard VU service is much better than Hisense.
According to reviews, VU Gloed PQ is on par with U6G not sure if this is true. I'm ok to spend an extra 5k but I want the best PQ with service reliability.
According to my research, Hisense ASS is terrible and VU's service is much better. Can someone share their experience dealing with these companies? Finally, as of now, VU is priced at 34k with offers and Hisense around 44k with offers.
FYI: FOMO:
U6G PROS:
U6G CONS:
  • no HDMI 2.1
VU GloLED PROS:
  • Newer Model
VU GloLED CONS:
  • No FLAD
  • Not a QLED Panel
FALD with 700 nits brightness would have been my deal makers. If you don't plan to game at 120hz or using eArc, then U6G is a better choice.
Hey, Thanks for the reply. VU Gloed doesn't have 120hz.. it is a 60hz panel.
I would be using an external 5.1 setup (Dolby Digital Plus or DTS)
Does having an eARC make any difference? is it worth spending 5-8k more for U6G?
Sound quality is okay, viewing angle are better but picture quality is quite good, just not as good as oled which i also have.
alright, if sound quality is manageable then I might go for U6G then. Vu Gloed has a 100w speaker with eARC support. But yeah.. as many suggested, I might get U6G for FLAD.
Any TV with a 100W speaker will still not serve your needs for 5.1 or 7.1 sound. Hence I'd ignore the 100W aspect of that TV entirely.
FALD/ QLED will result in a significant improvement in picture quality. You'll anyway get a home theater for better sound.
Warranty of 2 vs. 3 is certainly significant, just keep your fingers crossed and go for the FALD/ QLED panel
VU glo masterpiece television original images attached # true masterpiece with 3 years warranty
VU gloled use Google os version 11 while hisense u6g has android os,version 9,but vu doesn't have full array local dimming and quantum dot layers, 400 nits brightness while u6g is qled with full array local dimming and doesn't have earc port. I prefer u6g
