Need suggestions of Subwoofer and surrounds for Yamaha rxv585
karteek23
hyderabad
From past year I am looking to buy AV receivers and speakers I checked dealers and took demos of denon 1700h , Yamaha A2 etc. But due to chip shortage and various other reasons prices rised a lot
Luckily one of my friend upgrading his system from 5.12 to 7.2.4. so I grabbed his Yamaha Rxv585 and BIC AMERICA VENTUR BOOKSHELF(LCR) AND CENTER CHANNEL 6.5"
I am looking for good subwoofer , surround speakers, selected one from taga harmony 12", mission 12".
Can anyone suggest which one to go with or else can you suggest any other which can sound good in budget range.
I had RX-V585 and was using below speakers(in 5.1 config) with it. Very happy with the setup.
Wharfedale Diamond 230 - Front L/R
Wharfedale Diamond 220C - Center
NHT super zero - Surround L/R
Wharfedale D10 - Subwoofer
You can get any cheap surround option and add a good sub. Write down your budget too.
Surrounds Iam getting jamo 99$ pair from US.
Subwoofer iam looking in ₹40k budget
Yamaha NSW -300
Taga Harmony tsw-200
Mission sub , i have in my mind any other within the budget will check for demos
Yamaha NSW -300
Look at Bic
Out of my budget. Max ₹40k is my budget
You can also look at BIC subs. There is one for sale in the classified section
in dilemma between POLK hts 10' and taga harmony 212 se to consider. There are other two jbl stage a100p and elac 10.2 but I don't know about there performances.
Sound from taga harmony tsw 212se is very low,
I kept volume fully, phase 0°, crossover 80.
Connected by Amazon basics cable LfE in(subwoofer) to Yamaha rxv585 subwoofer preout (1).
Yamaha speaker configuration:
Front, left speakers set to <small>
Subwoofer <Use>
Phase< normal>
Please help me.
I changed my FrontLeft/Right to W.diamond 230.
Shifted present BIC bookshelf to rear surround.
Subwoofer <Use>
Phase< normal>
Please help me.
your problem solved or still facing ths issue
